2x Freematics ONE+ Traccar Edition aren't working
trackernsw
Re: 2x Freematics ONE+ Traccar Edition aren't working
Post by trackernsw »
I'm back from the car.
Still the same problem.
One is working but receiving the wrong GNSS signal its showing Latitude = 0.000000°Longitude =0.000000°
The second one is not working at all
trackernsw
When i changed the line on the FreematicsPlus.cpp (the library, ticked the rebuild libs. after building. then selecting the COM3, there is a blank screen no outputs are given.
Freematics Builder version 1.2 was just released. I suggest you doing an upgrade. If still no luck, please use PlatformIO or Arduino IDE.
https://github.com/stanleyhuangyc/Freem ... ag/builder
If you still see GNSS:NO there shouldn't be any coordinates. Can you confirm you've got GNSS:OK?
trackernsw
Good morning,
Regarding the new version of Freematics Builder, should i also change the value for #define VERBOSE_XBEE 1 in FreematicsPlus.cpp (the library)
Regarding the GNSS, it was supplied by you, my Order 13289.
Yes both.
All your parts were tested together before shipping. Could you take a picture of your devices when you test them?
trackernsw
Hi Stanley.
Your new update is generating errors. Please see attached.
Also, the config settings are different on this new version, can't select sim apn, external gnss, ....
When can I start tracking my vehicles its been more than 1-2 weeks now.
That issue was fixed. Please download and install version 1.2 again. Please also update your code from github.
trackernsw
I don't think so the problem is solved yet.
*downloaded the latest code from GitHub and reinstalled the builder too.
(I need to get this tracker by working tomorrow lastest.)
Please use PlatformIO or Arduino IDE if you can't get our utility to work which is provided as a courtesy.
