Which cellular module do you have in the units? Which operator did you see from serial output when you using hologram sim card?
trackernsw
Which cellular module do you have in the units? IDK
Which operator did you see from serial output when you using hologram sim card? optus au
I assume you have SIM7600E-H in your units which works on Optus network. I use Optus myself and never had an issue. Please show me the serial output when you use Optus sim cards.
trackernsw
CPU:160MHz FLASH:4MB
IRAM:351KB
DEVICE ID:E5910RGP
TYPE:16
MEMS:ICM-20948
ACC BIAS:-0.00/-0.02/1.01
GNSS:OK
CELL:SIM7600E-H
OBD:NO
[ 11337][E][sd_diskio.cpp:126] sdSelectCard(): Select Failed
[ 11337][E][sd_diskio.cpp:790] sdcard_mount(): f_mount failed: (3) The physical drive cannot work
NO SIM CARD
[ 11641][E][sd_diskio.cpp:126] sdSelectCard(): Select Failed
NO SD CARD
CELL OFF
[BUF] 12 samples | 104 bytes | 12%
[BUF] 21 samples | 182 bytes | 21%
[BUF] 30 samples | 260 bytes | 31%
[BUF] 39 samples | 338 bytes | 40%
[BUF] 47 samples | 410 bytes | 50%
[BUF] 56 samples | 488 bytes | 59%
[BUF] 64 samples | 560 bytes | 68%
[BUF] 73 samples | 638 bytes | 78%
[BUF] 82 samples | 716 bytes | 87%
[BUF] 91 samples | 794 bytes | 96%
[BUF] 94 samples | 820 bytes | 100%
[BUF] 93 samples | 814 bytes | 100%
[BUF] 92 samples | 808 bytes | 100%
[BUF] 91 samples | 802 bytes | 100%
CELL:NO
CELL OFF
CELL:SIM7600E-H
NO SIM CARD
CELL OFF
Port closed
IRAM:351KB
DEVICE ID:E5910RGP
TYPE:16
MEMS:ICM-20948
GNSS:OK
CELL:SIM7600E-H
OBD:NO
NO SIM CARD
NO SD CARD
CELL OFF
CELL:NO
CELL OFF
CELL:SIM7600E-H
NO SIM CARD
CELL OFF
Port closed
trackernsw
Above is the serial output,
Regarding installation of the sim card & sd card is the same in the guide = https://freematics.com/pages/products/f ... art-guide/
APN: connect
Wondering how is the sd card failing, it's brand new it came with the order?
APN: connect
trackernsw
another round of serial ouput.
IRAM:351KB
DEVICE ID:E5910RGP
TYPE:16
MEMS:ICM-20948
ACC BIAS:0.00/-0.02/1.01
GNSS:OK
OBD:NO
SD:29832 MB total, 1 MB used
1.CSV
2.CSV
3.CSV
4.CSV
5.CSV
6.CSV
7.CSV
8.CSV
9.CSV
10.CSV
11.CSV
12.CSV
13.CSV
14.CSV
15.CSV
16.CSV
17.CSV
File: /DATA/1.CSV
CELL:SIM7600E-H
[BUF] 11 samples | 98 bytes | 12%
[BUF] 19 samples | 170 bytes | 21%
NO SIM CARD
[BUF] 26 samples | 236 bytes | 31%
CELL OFF
[BUF] 35 samples | 314 bytes | 40%
[BUF] 44 samples | 392 bytes | 50%
[BUF] 52 samples | 464 bytes | 59%
[BUF] 61 samples | 542 bytes | 68%
[BUF] 70 samples | 620 bytes | 78%
[BUF] 79 samples | 698 bytes | 87%
[BUF] 88 samples | 776 bytes | 96%
[FILE] 1KB
[BUF] 89 samples | 790 bytes | 100%
CELL:SIM7600E-H
NO SIM CARD
CELL OFF
IRAM:351KB
DEVICE ID:E5910RGP
TYPE:16
MEMS:ICM-20948
GNSS:OK
OBD:NO
1.CSV
2.CSV
3.CSV
4.CSV
5.CSV
6.CSV
7.CSV
8.CSV
9.CSV
10.CSV
11.CSV
12.CSV
13.CSV
14.CSV
15.CSV
16.CSV
17.CSV
File: /DATA/1.CSV
CELL:SIM7600E-H
NO SIM CARD
CELL OFF
[FILE] 1KB
CELL:SIM7600E-H
NO SIM CARD
CELL OFF
SIM card not inserted correctly or you are using a not very proper SIM adapter.
trackernsw
Using a new sim, with the Freematics ONE tracker. that's it.
I'm 100% sure its inserted correctly, like in the guide https://freematics.com/pages/products/f ... art-guide/
trackernsw
Images of how the sim card & sd card is installed
- 3.PNG (55.56 KiB) Viewed 29931 times
- 2.PNG (91.53 KiB) Viewed 29931 times
- 1.PNG (130.81 KiB) Viewed 29931 times
trackernsw
and this one too
- 4.PNG (110.89 KiB) Viewed 29931 times
