Cannot read Kona EV custom PIDS
tavius
Post by tavius »
Hello:
This is driving me crazy. I'have tried all can procotols to retrieve custom PID 220101 and 220105 from Hyundai kona (header 7E4) and I don't receive nothing. In auto it said unable to connect.
char *SendObdCommand(char *msg, unsigned int timeout)
  static char command[32], buffer[1024];
  sprintf(command, "%s\r", msg);
  Serial.println(command);
  obd.link->sendCommand(command, buffer, sizeof(buffer), timeout);
  for (int f = 0; f < strlen(buffer); f++)
    if (buffer[f] == '\r')
      buffer[f] = '\n';
  Serial.println(buffer);
  delay(1000);
  return (buffer);
void setup()
  char buffer[128];
  if (sys.begin())
    pinMode(PIN_LED, OUTPUT);
    digitalWrite(PIN_LED, HIGH);
    delay(1000);
    digitalWrite(PIN_LED, LOW);
    Serial.begin(115200);
    Serial.print("TYPE:");
    Serial.println(sys.devType);
    Serial.println("Calling obd.begin");
    obd.begin(sys.link);
    for (int f = 3; f < 10; f++)
      SendObdCommand((char *)"ATZ", OBD_TIMEOUT_SHORT);
      SendObdCommand((char *)"ATE0", OBD_TIMEOUT_SHORT);
      SendObdCommand((char *)"ATL0", OBD_TIMEOUT_SHORT);
      SendObdCommand((char *)"ATS0", OBD_TIMEOUT_SHORT);
      SendObdCommand((char *)"ATH1", OBD_TIMEOUT_SHORT);
      sprintf(buffer,"ATSP%X",f);
      SendObdCommand((char *)buffer, OBD_TIMEOUT_SHORT);
      SendObdCommand((char *)"ATSH7E4", OBD_TIMEOUT_SHORT);
      SendObdCommand((char *)"220101", OBD_TIMEOUT_LONG);
      SendObdCommand((char *)"220105", OBD_TIMEOUT_LONG);
This is the output....
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP3
ATSH7E4
ERROR
220101
BUS
INIT:
...ERROR
ATSH7E4
ERROR
220105
BUS
INIT:
...ERROR
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP4
ATSH7E4
220101
BUS
INIT:
...ERROR
ATSH7E4
220105
BUS
INIT:
...ERROR
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP5
ATSH7E4
220101
BUS
INIT:
...ERROR
ATSH7E4
220105
BUS
INIT:
...ERROR
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP6
ATSH7E4
220101
NO DATA
ATSH7E4
220105
NO DATA
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP7
ATSH7E4
220101
NO DATA
ATSH7E4
220105
NO DATA
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP8
ATSH7E4
220101
NO DATA
ATSH7E4
220105
NO DATA
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP9
ATSH7E4
220101
NO DATA
ATSH7E4
220105
NO DATA
Does anybody know the correct way to retrieve customs pids with freematics+ model H. I'm starting to think this interfaces is useless for me :(
Thanks in advance.
Octavio.
Re: Cannot read Kona EV custom PIDS
Only standard OBD PIDs are supported. Custom PIDs are not guaranteed to work. You can try CAN sniffing though.
tavius
Post by tavius »
I do not understand. With other ELM327 OBD interfaces I can query this customs PIDS. Where is the limitation? In the chips used in freematics? The firmware?.
Thanks.
Octavio.
Deferral7391
Post by Deferral7391 »
I followed along with my Freematics ONE+ Model B and Kia EV6 (same platform as Hyundai Ioniq 5) and was able to read 220101 and 220105:
AT@1
OBDII to USART Interpreter
>ATZ
ELM327 v1.5
>ATE0
>ATH0
>ATSP6
>ATSH 7E4
>ATMA
>ATCFC1
>ATCM7FF
>ATCF7EC
>220101
03E 0: 62 01 01 EF FB E7
1: EF 6D 00 00 00 00 00
2: 00 09 1C 14 13 12 13
3: 13 12 12 12 00 3C BB
4: 27 BB 08 00 00 87 00
5: 00 06 DC 00 00 06 F1
6: 00 00 05 29 00 00 05
7: 11 00 08 EB 52 00 02
8: CE 00 00 00 00 06 B0
>220105
02E 0: 62 01 05 FF FB 74
1: 0F 01 2C 01 01 2C 12
2: 12 12 12 12 12 12 6C
3: 34 6C 34 00 00 50 14
4: 00 03 E8 00 49 A4 00
5: 6C 00 00 00 00 00 00
6: 00 12 12 13 12 00 00
No clue how to interpret this yet but looks like it's possible to talk to EVs.
ankostis
Post by ankostis »
Interesting, thanks!
How did you send the AT-commands?
