This is driving me crazy. I'have tried all can procotols to retrieve custom PID 220101 and 220105 from Hyundai kona (header 7E4) and I don't receive nothing. In auto it said unable to connect.
char *SendObdCommand(char *msg, unsigned int timeout)
static char command[32], buffer[1024];
sprintf(command, "%s\r", msg);
Serial.println(command);
obd.link->sendCommand(command, buffer, sizeof(buffer), timeout);
for (int f = 0; f < strlen(buffer); f++)
if (buffer[f] == '\r')
buffer[f] = '\n';
Serial.println(buffer);
delay(1000);
return (buffer);
void setup()
char buffer[128];
if (sys.begin())
pinMode(PIN_LED, OUTPUT);
digitalWrite(PIN_LED, HIGH);
delay(1000);
digitalWrite(PIN_LED, LOW);
Serial.begin(115200);
Serial.print("TYPE:");
Serial.println(sys.devType);
Serial.println("Calling obd.begin");
obd.begin(sys.link);
for (int f = 3; f < 10; f++)
SendObdCommand((char *)"ATZ", OBD_TIMEOUT_SHORT);
SendObdCommand((char *)"ATE0", OBD_TIMEOUT_SHORT);
SendObdCommand((char *)"ATL0", OBD_TIMEOUT_SHORT);
SendObdCommand((char *)"ATS0", OBD_TIMEOUT_SHORT);
SendObdCommand((char *)"ATH1", OBD_TIMEOUT_SHORT);
sprintf(buffer,"ATSP%X",f);
SendObdCommand((char *)buffer, OBD_TIMEOUT_SHORT);
SendObdCommand((char *)"ATSH7E4", OBD_TIMEOUT_SHORT);
SendObdCommand((char *)"220101", OBD_TIMEOUT_LONG);
SendObdCommand((char *)"220105", OBD_TIMEOUT_LONG);
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP3
ATSH7E4
ERROR
220101
BUS
INIT:
...ERROR
ATSH7E4
ERROR
220105
BUS
INIT:
...ERROR
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP4
ATSH7E4
220101
BUS
INIT:
...ERROR
ATSH7E4
220105
BUS
INIT:
...ERROR
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP5
ATSH7E4
220101
BUS
INIT:
...ERROR
ATSH7E4
220105
BUS
INIT:
...ERROR
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP6
ATSH7E4
220101
NO DATA
ATSH7E4
220105
NO DATA
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP7
ATSH7E4
220101
NO DATA
ATSH7E4
220105
NO DATA
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP8
ATSH7E4
220101
NO DATA
ATSH7E4
220105
NO DATA
ATZ
ELM327 v1.5
ATE0
ATL0
ATS0
ATH1
ATSP9
ATSH7E4
220101
NO DATA
ATSH7E4
220105
NO DATA
Thanks in advance.
Octavio.
