MegaLoggerHD is released
MegaLoggerHD is a reworked version of MegaLogger which targets at the new Telematics Shield with 3.5" LCD of 480x320 resolution. It supports both Freematics OBD-II I2C Adapter and UART Adapter V2 (by switching in config.h). The code has just been committed to github. This is the initial revision. Subsequent improvements will be followed.
https://github.com/stanleyhuangyc/Ardui ... galoggerHD
PS: Make sure to update your OBD library before compiling the sketch.
onche
Re: MegaLoggerHD is released
Post by onche »
I tried to compile but i ave the following error (see picture).
I updated all the libraries etc....
Did you uploaded the wrong files ?
Cheers
EDIT:
I changed the megaloggerHD sketch from "lcd.draw2x" to "lcd.draw4bpp"
void initScreen()
lcd.clear();
lcd.draw4bpp(frame0[0], 78, 78);
lcd.setXY(162, 0);
lcd.setXY(324, 0);
lcd.setXY(0, 164);
lcd.setXY(162, 164);
lcd.setXY(324, 164);
Could you please add a bigger font (at least 3 times) so that we can actual read the screen values while driving ? Or please explain how to code the fonts.h file. THanks
Please update MultiLCD library. Latest sketch and libraries package can downloaded here.
Will add 2x font display soon.
onche
Post by onche »
Hello, do you have any updates for the fonts ?
Thank you
onche
Post by onche »
hello, do you have any news on putting bigger fonts ?
