Set MIL to Off ?
Re: Set MIL to Off ?
What specific DTC is still left on?
itsmagic
Post by itsmagic »
The DTC causing the MIL is P0105 and it cnanot be cleared from the UI or the serial port. The stored
freeze frame DTC's all say: "Fault Definition Not Available or Manufacturer Specific" on my OBD scanner.
They are also not clearable.
Please update the firmware of your emulator. Firmware is included in the GUI software package.
http://freematics.com/pages/software/fr ... lator-gui/
itsmagic
Post by itsmagic »
I installed the brand new firmware and GUI you mentioned above.
Unfortunately the new Version 1.0-20150509 firmware and GUI did NOT address the described problems.
After installing, MIL is still on, The freeze frame still has: DTCFRZF = P0105 and DTC_CNT is
still 6 with Six stored freezeframe DTC's. I tried clearing the DTC's and MIL... no joy. :-(
*Please* fix this.
Did you upgrade the firmware? Latest firmware revision is 20150509.
itsmagic
Post by itsmagic »
Yes. As stated in my post above: Version 1.0-20150509 firmware which is the latest.
The new firmware does not fix the MIL = ON or the freezeframe DTC's. If you try your's,
you will see it right away.
I was informed by several emulator users that this issue is fixed by the firmware upgrade.
cuyusa
Post by cuyusa »
stanley can you explain how are we doing this?? with out individual help (team viewer) please or configurate the software when this issue affecting your wonderful product....
itsmagic
Post by itsmagic »
I have updated the firmware to the new level and repeated it a couple of times, all attempts have had the same results:
Hex file: Firmware_20150509.hex Installs, but MIL is still on with 6 Freezeframe DTC's
Hex file: Firmware_J1850_20150509.hex Installs, but the GUI will then not connect to emulator.
If others try this upgrade, please post and let us know your results.
Please upgrade the latest firmware released in July 2015 and it will competely fix this issue.
