Has anyone determined a way to set MIL off? As other have mentioned, with the latest 8/20 GUI and firmware,
MIL is on (with several freezeframes stored). Is it possible to force MIL off through the serial port via the ATSET
interface? Does anyone have a incantation to do so? Thanks for any help.
Set MIL to Off ?
Re: Set MIL to Off ?
The new (December 9) firmware looks good. However, after updating the firmware and clearing DTC's,
MIL is still set ON and there is still a freezeframe stored with six DTC's. Stanley, is this working as designed
or will it be fixed? Thanks.
I am also having similar issues. The mil status is always on and there seem to be 6 dtc's stored in the system, but when scanning it they don't show.
can this be fixed?
can this be fixed?
Does anyone know how to turn MIL off yet?
Anyone? I'm getting so fed up with this lol
Same problem here! When will there be a fix available?
STANLEY!!!!! Can I return this paperweight? Or can you do something about this problem
Have you tried sending via serial?
ATCLR DTC
ATCLR DTC is accepted, but MIL stays on and the stored DTC's are still present after doing it... so no good.
