trackernsw
Post by trackernsw »
thanks for the reply.
so for the Arduino IDE, which Arduino library do I need to download, to use the tracker for a traccar server.
according to your blog post: https://blog.freematics.com/2017/settin ... h-arduino/
Link to the download to the library is dated to 2017 - FreematicsONE-Plus-20170911.zip
Confused about what library to use?
If you use PlatformIO, you can just load firmware_v5/telelogger project folder. If you use Arduino IDE, you need to manually copy FreematicsPlus directory to Arduino's libraries folder. Make sure to use the latest code from Github.
trackernsw
Finally, I got the trackers to work.
So one of the hologram sim cards you send isn't working.
Wondering the rate of data being sent to the server? is it every 10 seconds? if so I could I change this x value?
By default it is one second. You can configure data interval in config.h. It's a staged setting depending on whether vehicle is moving.
Can the hologram sim card be activated normally? You can apply for one free sim card from hologram directly.
trackernsw
the sim card is already activated and ready, however, it's not working at all.
is this line for data interval = #define DATA_INTERVAL_TABLE {1000, 2000, 5000} /* ms */
when the vehicle is moving?
i would like to have it set to every 15 seconds when moving.
trackernsw
could it be like this;
#define DATA_INTERVAL_TABLE {15000, 30000, 50000} /* ms */
Correct.
trackernsw
Thanks for the help, Stanley.
Sorry for the hassle for the past days, it was frustrating that it wasn't working.
But actually disappointed that one sim isn't working.
Once again thanks, Stanley.
Cheers.
trackernsw
hey,
Wondering why is the tracker working on two trips a day.
Today and yesterday, only two trips were being tracked. (daily there are around 20 trips per vehicle)
trackernsw
also, I received my Optus sims = Mobile Broadband Sim.
However, can't get the sim to work with the tracker.
Different apn's were given by Optus, I tried them all, not working.
using the platform.io method
