trackernsw
Post by trackernsw »
Hey,
I purchased 2 x Freematics ONE+ Traccar Edition
After doing the Freematics Builder configuration according to the guide. (both trackers were configured the same, same place, same PC and same sim providers "hologram") Yesterday two trackers were also tested on the road on two vehicles, and results follow;
  • First Tracker: Was connecting to the sim network & server, but when connected to OBD, the coordinates were showing Latitude 0.000000°, Longitude 0.000000°forwhole road trip.
    SecondTracker: Wasn't connecting to server and sim provider.
Below are the outputs from the Freematics Builder console
First Tracker
E (202) spiram: SPI RAM not initi +K 5
E (202) esp_himem: Cannot allocate memory for meta info. Not initializing!
CPU:160MHz FLASH:4MB
IRAM:359KB
DEVICE ID:E5910RGP
TYPE:16
MEMS:ICM-20948
ACC BIAS:0.01/-0.02/-1.02
GNSS:NO
CELL:SIM7600E-H
IMEI:860147050686862
OBD:NO
SD:29832 MB total, 0 MB used
/DATA/1.CSV
/DATA/2.CSV
/DATA/3.CSV
/DATA/4.CSV
/DATA/5.CSV
/DATA/6.CSV
/DATA/7.CSV
File: /DATA/8.CSV
Operator:Optus AU Hologram
[BUF] 11 samples | 98 bytes | 12%
IP:100.66.160.120
RSSI:-95dBm
LOGIN(track.egemeats.com.au:5170)...
[BUF] 20 samples | 176 bytes | 21%
[BUF] 29 samples | 254 bytes | 31%
[BUF] 37 samples | 326 bytes | 40%
Server timeout
[BUF] 45 samples | 398 bytes | 50%
[BUF] 54 samples | 476 bytes | 59%
[BUF] 63 samples | 554 bytes | 68%
[BUF] 72 samples | 632 bytes | 78%
Unable to connect
[BUF] 81 samples | 710 bytes | 87%
[BUF] 90 samples | 788 bytes | 96%
[BUF] 92 samples | 808 bytes | 100%
[FILE] 1KB
[BUF] 93 samples | 814 bytes | 100%
Unable to connect
[BUF] 91 samples | 802 bytes | 100%
Unable to connect
Second tracker
IRAM:359KB
DEVICE ID:E591GAG4
TYPE:16
MEMS:ICM-20948
ACC BIAS:1.00/-0.02/-0.06
GNSS:NO
CELL:SIM7600E-H
IMEI:860147050679503
OBD:NO
SD:29832 MB total, 1 MB used
/DATA/1.CSV
/DATA/2.CSV
/DATA/3.CSV
/DATA/4.CSV
/DATA/5.CSV
/DATA/6.CSV
/DATA/7.CSV
/DATA/8.CSV
/DATA/9.CSV
/DATA/10.CSV
/DATA/11.CSV
/DATA/12.CSV
/DATA/13.CSV
/DATA/14.CSV
/DATA/15.CSV
/DATA/16.CSV
/DATA/17.CSV
/DATA/18.CSV
/DATA/19.CSV
/DATA/20.CSV
/DATA/21.CSV
/DATA/22.CSV
/DATA/23.CSV
/DATA/24.CSV
File: /DATA/25.CSV
[BUF] 12 samples | 104 bytes | 12%
[BUF] 21 samples | 182 bytes | 21%
[BUF] 38 samples | 332 bytes | 40%
[BUF] 47 samples | 410 bytes | 50%
[BUF] 55 samples | 482 bytes | 59%
NO SERVICE,Online
[BUF] 89 samples | 782 bytes | 96%
CELL OFF
[FILE] 1KB
CELL:SIM7600E-H
NO SERVICE,Online
CELL OFF
CELL:SIM7600E-H
Did you connect GPS receiver as I see you have model A and no GNSS is detected. Try powering from OBD instead of USB alone which might not supply sufficient power surge.
trackernsw
I did connect the external GNSS.
Both connections have been tried (from OBD and USB Hub)
If you see GNSS:NO there is no chance any coordinates will be obtained. GNSS receivers are not detected for some reason. Have you tried both receivers?
As for the cellular network issue, did you test with the same SIM card that works in another unit?
trackernsw
Let me swap the sim cards and receivers. I will let you know, in 20 minutes
trackernsw
stanley wrote: Thu Oct 28, 2021 10:26 am If you see GNSS:NO there is no chance any coordinates will be obtained. GNSS receivers are not detected for some reason. Have you tried both receivers?
Done a test on the 2. device
IRAM:359KB
DEVICE ID:E591GAG4
TYPE:16
MEMS:ICM-20948
ACC BIAS:0.03/-0.01/0.99
GNSS:NO
OBD:NO
/DATA/1.CSV
/DATA/2.CSV
/DATA/3.CSV
/DATA/4.CSV
/DATA/5.CSV
/DATA/6.CSV
/DATA/7.CSV
/DATA/8.CSV
/DATA/9.CSV
/DATA/10.CSV
/DATA/11.CSV
/DATA/12.CSV
/DATA/13.CSV
/DATA/14.CSV
/DATA/15.CSV
/DATA/16.CSV
/DATA/17.CSV
/DATA/18.CSV
/DATA/19.CSV
/DATA/20.CSV
/DATA/21.CSV
/DATA/22.CSV
/DATA/23.CSV
/DATA/24.CSV
/DATA/25.CSV
/DATA/26.CSV
/DATA/27.CSV
File: /DATA/28.CSV
CELL:SIM7600E-H
[BUF] 56 samples | 488 bytes | 59%
[BUF] 65 samples | 566 bytes | 68%
[FILE] 1KB
CELL OFF
CELL:SIM7600E-H
CELL OFF
[FILE] 2KB
CELL:SIM7600E-H
Stationary for 180 secs
STANDBY
ACC BIAS:-0.01/-0.01/0.99
CELL OFF
trackernsw
Done a test on the 1. device
IRAM:359KB
DEVICE ID:E5910RGP
TYPE:16
MEMS:ICM-20948
ACC BIAS:0.00/-0.25/-0.99
GNSS:NO
CELL:SIM7600E-H
OBD:NO
/DATA/1.CSV
/DATA/2.CSV
/DATA/3.CSV
/DATA/4.CSV
/DATA/5.CSV
/DATA/6.CSV
/DATA/7.CSV
/DATA/8.CSV
/DATA/9.CSV
/DATA/10.CSV
/DATA/11.CSV
/DATA/12.CSV
File: /DATA/13.CSV
[BUF] 19 samples | 170 bytes | 21%
[BUF] 28 samples | 248 bytes | 31%
[BUF] 80 samples | 704 bytes | 87%
NO SERVICE,Online
[BUF] 88 samples | 776 bytes | 96%
CELL OFF
[FILE] 1KB
trackernsw
tests were done on my desk, let me try it on OBD.
Make sure to always change the GNSS option to external while compiling as you use external one.
Please also change following line in FreematicsPlus.cpp (the library) so more information can be obtained. Tick "Rebuild libs" before compiling again.
#define VERBOSE_XBEE 1
