I recently purchased the OBDII-UART adapter v2.1, naïvely assuming that my vehicle uses one of the supported protocols. I have come to find out that it uses VPW J1850 which is not listed as a supported protocol. Is there a way I might be able to modify the Arduino library to support it, or if not, is there another product that supports this protocol (ideally compatible with the Arduino library)?
UART Adapter - VPW J1850 Protocol
Re: UART Adapter - VPW J1850 Protocol
J1850 can't be supported by changing any Arduino code.
