Freematics ONE+ Traccar Edition - standby when not moving?
sboldt
Post by sboldt »
I'm using Freematics ONE+ Traccar Edition with the telelogger firmware since a couple of days. What keeps me wondering is that the device seems to send data all the time. Even after hours of parking I still see a "last update" of 0 minutes. Shouldn't it go into a standby mode when not moving for some time? I'm concerened about both the volume of data that is unnecessarily transmitted but also battery power consumption. When not driving for a couple of days I'm afraid my car won't start - especially during cold winter times. Is there no such thing as auto-standby? Or are there situations that prevent standby? EG ODB timeouts (just opened another thread regarding that problem)?
Thanks in advace for any hint!
regards,
Stephan
Re: Freematics ONE+ Traccar Edition - standby when not moving?
There is a designated standby mode. Can you check one thing for me. Does your car's OBD still accessible when key is off?
UPDATE: I just committed a fix to github.
sboldt
Post by sboldt »
I'm gonna check out your fix. My car (current Mazda 6) provides power to the ODB port all the time, regardless whether the key is off or on, but I get ODB timeouts when key is off.
Wouldn't it be a good idea to ignore GPS data when the motion sensor tells that the car is not moving or satellite signal is very low? This would prevent false coordinates when driving into a tunnel or a car park. Because of different use cases I think it would be good to have the signal threshold customizable using a variable in config.h.
regards,
Stephan
sboldt
Post by sboldt »
your fix didn't work for me, but I might also have an additional issue here: I'm not getting any GPS related output anymore. :-( Also the "simple_gps_test.ino" sketch doesn't give any output (Except from (SIMPLE GPS TEST"). Might be my receiver (that I received just a week ago) is faulty? This is also the case when using a fresh clone of your git repo... Help! :-(
regards,
Stephan
simple_gps_test only works with external GPS receiver and will not work with the unit you have.
sboldt
Post by sboldt »
OK, but I cannot get any GPS position anymore - with the same sketches that worked a couple of days ago. Please tell me what to do to get it fixed. What data can I send you for an analysis?
kind regards,
Stephan
Did you use telelogger?
sboldt
Post by sboldt »
stanley wrote: Fri Jul 02, 2021 12:42 pm Did you use telelogger?
Yes, I'm using telelogger. The serial output is always like that - no matter if I'm inside or outside. Currently there is no SIM card attached and its not connected to the odb2 port but it's the same with SIM installed and OBD2 connection (of course apart from the SIM and OBD messages):
ACC BIAS:0.24/-0.33/-0.86
GNSS:OK
CELL:SIM7600E-H
OBD:NO
SD:29807 MB total, 25 MB used
/DATA/2.CSV
/DATA/3.CSV
/DATA/4.CSV
/DATA/5.CSV
/DATA/6.CSV
/DATA/7.CSV
/DATA/8.CSV
/DATA/9.CSV
/DATA/10.CSV
/DATA/11.CSV
/DATA/12.CSV
/DATA/13.CSV
/DATA/14.CSV
/DATA/15.CSV
/DATA/16.CSV
/DATA/17.CSV
/DATA/18.CSV
File: /DATA/19.CSV
[FILE] 0KB
NO SIM CARD
[BUF] 15 samples | 130 bytes | 15%
CELL OFF
[BUF] 27 samples | 234 bytes | 28%
[BUF] 36 samples | 312 bytes | 37%
[BUF] 43 samples | 378 bytes | 46%
[BUF] 50 samples | 444 bytes | 56%
[BUF] 59 samples | 522 bytes | 65%
[BUF] 68 samples | 600 bytes | 75%
[BUF] 76 samples | 672 bytes | 84%
[BUF] 83 samples | 738 bytes | 93%
[BUF] 88 samples | 784 bytes | 100%
[BUF] 87 samples | 778 bytes | 100%
[FILE] 1KB
CELL:SIM7600E-H
[BUF] 86 samples | 772 bytes | 100%
NO SIM CARD
CELL OFF
CELL:SIM7600E-H
NO SIM CARD
CELL OFF
CELL:SIM7600E-H
[BUF] 89 samples | 790 bytes | 100%
NO SIM CARD
CELL OFF
You need to put in a SIM card. Otherwise use datalogger.
sboldt
Post by sboldt »
Well, as I wrote it's the same with a SIM put in. But as requested I installed datalogger firmware and even after several minutes I get GPS->ready->"no" in the webinterface. Serial output is also shown in the other screenshot.
GPS -> Ready -> No even after several minutes
Mozilla Firefox - (Privater Modus) 2021-07-09 10-53-50.png (61.04 KiB) Viewed 13509 times
That's how the serial output looks like
dataserver.cpp — Untitled (Workspace) 2021-07-09 10-57-03.png (234.26 KiB) Viewed 13509 times
