I purchased Freematics Traccar Edition (promo code didn't work btw). Setup wasn't without a problem.
The official documentation here was not very helpful, since firmware_v5 folder has multiple libraries to load to the device. I loaded /firmware_v5/telelogger/telelogger.ino, then edited settings in the Freematics Windows program (connected to my server via WiFi connection, UDP 5170, location data provided with internal GNSS). The device was not connected to OBD-II in a car, but I had a walk with it instead.
Freematics ONE+ setup problems
michaelgrubbs
ArvillaKovacek
Re: Freematics ONE+ setup problems
I'm also struggling to set up the traccar version (i haven't even got to Traccar bit yet)
I'm trying to update to latest build incase there's bugs in the factory supplied code. I've latest V5 folder from github including libraries.
I am unable to compile in builder 1.3 (error -4)
Unable to compile in VSCode PIO (47 errors in MEMS + 1 error in dataserver)
The app connects to device (with factory installed firmware from April 2023) via BT and is stable in Android, but 'flaky as' in IOS
I am unable to define Wifi SSID or PW through App, when watching serial console I see same error there (unable to apply change) I can see basic stats + GNSS in console and app
Is there a wiki with decent instructions? as i feel something obvious is missing...
How do i update and connect to wifi?
