Operational problems with Freematics ONE+ Model A GPS
outfieldgrease
Post by outfieldgrease »
I upgraded my Freematics ONE+ Model A software to the current version, however the GPS still does not work. I used to develop the software using GNSS_EXTERNAL and it worked great with the new setup. GNSS_STANDALONE does not recognize the external GPS.
reverting to the old code on git re-compiling and it works again so its not a hardware problem
what am I missing in the setup of config.h freemaic builder etc?
jaibarra
Re: Operational problems with Freematics ONE+ Model A GPS
Post by jaibarra »
Hi, I'm also trying to get the GPS working on my Freematics Traccar Edition, which is a Model B I believe. I get constant 0,0 coordinates with the latest version of the software. Which commit are you using when you say it does work?
Eugeghes
Post by Eugeghes »
Ensure that the settings in config.h are correctly configured for GNSS_STANDALONE. Compare your current config.h with the previous version where GNSS_EXTERNAL was working and verify that necessary parameters are correctly set for GNSS_STANDALONE.
