H all,
I want to use the One+ to log the complete CAN-Data from the OBD2 Pins 6/14. About 800 messages/second.
But - the CAN-Transceiver in the ONE+ is connected to the STM32, not the ESP32. Therefore, I cannot use the standard ESP32-CAN-libraries (Twai/Can.h). Is there any library to access the CAN-Bus connected to the STM32 via the UART-Communication from the ESP32?
(I'm running FreeRTOS on the ONE+)
Best,
Sebastian
						CAN-Bus access from ESP32 (One+)
Re: CAN-Bus access from ESP32 (One+)
ESP32 is not automotive level and we found it could cause various issues when accessing a real vehicle's CAN bus.
Thanks. I was convinced that there must be a deliberate thought behind it.
I just need to send a single message to the CAN-Bus, is there any best practice on how to do this? (Background Info: I need to collect odometer readings for a fleet tracking application; the dongle works fine for Tesla & Polestar 2 with the sniffer library, but for another model I need to send a trigger message to receive the response).
What's the specific message like to be sent?
Thanks for the quick reply. Something like this:
268#0010000000000000
That's for example the command to physically close the doors of my Tesla; a very "visual" test. No authentication needed beforehand.
Any idea how to accomplish this? It could even be with a sequence of AT-commands, whatever works to send a CAN-Message.
It would also help to set the vehicle into diagnostic code.
I had great success using the One+ to collect the odometer and VIN from my Polestar and the Tesla by just using the sniffer sample, for the Mercedes EQA others I would need to send a message, like
cansend can0 7E0#021A905555555555
on linux.
on linux.
We are looking into this. The Tesla message seems to be ISO11898 and is currently not supported.
Thanks for looking into this. It will help me a lot in my project. My customer just placed an initial order of another 10 dongles just to try. My prototype "hack" is to solder a TTL converter to the external pins and then back to 6/14 of the OBD2-Port - to send the command via the ESP32 internal can. But it does not feel right. The rest of the hardware / software stack is so nice, and the 16MB H-Version really makes a difference.
To send 7E0#021A905555555555
obd.setHeaderID(0x7E0);
obd.dataMode = 0x1A;
int value = obd.readPID(0x90);
Awesome! Thank you!
