CAN Bus Controller provided on Freematics One+ H
MakersGarage2021
Post by MakersGarage2021 »
We would like to know if there is a documentation of the CAN Bus controller used on the Freematics One+ H model.
As we need to mask the data received by the CAN Bus, we need to know details about the specific controller.
Thank you in advance, looking forward to your replies.
Best regards,
Makers Garage :)
Re: CAN Bus Controller provided on Freematics One+ H
You can use CAN sniffing mode to capture CAN data. The controller is not exposed to ESP32.
MakersGarage2021
But the CAN sniffing code works only for model B and not for model H. Is there any way that we could modify it so that it can be compatible with model H? We have been using J1939 monitor so far, which worked with model H, but we could only receive the data.
And one more question would be, how to place a request to the ECU using the freematics as we don't see any function related to placing the request in the code, but we only have the function to receive the data.
Best Regards
Makers Garage
seb
Post by seb »
Is there any update on this? Accessing CAN-Data gets more and more important.
The H ist great, because it can run FreeRTOS, but without fast access to the CAN-Data it's hard to use the potential of the device.
seb
Post by seb »
Is there any way to send CAN-Messages with the One+ H?
For example, to send 7E0#021A905555555555
obd.setHeaderID(0x7E0);
obd.dataMode = 0x1A;
int value = obd.readPID(0x90);
