Hey,
I am working on a project involving Hyundai Kona electric and I would like to log SoC and other custom PIDs using the Freematics One+ (Model A). I've tried going through the whole forum and tried a couple of things like sending AT commands which work to an extent but nothing further than that. (The result is displayed on the bottom). I searched for the PIDs and have them from GitHub but the real problem is, I cannot connect to the OBD port or sniff any data. Been trying this for a couple of weeks now.
I do believe some of the users have successfully done this with other EVs as well. So any help would be appreciated. Thanks in advance.
Sending ATZ
ELM327 v1.5
Sending ATI
OBD2USART V1.6
Sending ATH0
Sending ATRV
14.63V
Sending ATSP6
Sending ATDP
ISO 15765-4 (CAN 11/500)
Sending ATCFC1
Sending ATCM7FF
Sending ATCF7EC
Sending 2102
NO DATA
No DTC
Trouble working with One+ and EVs
Re: Trouble working with One+ and EVs
Only standard OBD PIDs (refer to wikipedia) are supported.
Hi Can_Bot,
I think we are trying to achieve more or less the same thing, but for another EVs (Renault ZOE and Peugeot e-208).
I would like to query some custom PIDs from 22 mode just like you but so far even the can_sniffing code isn't working (I only get the "uart: UART driver already installed" message when connected to those vehicles).
I'm wondering how did you end up sending those messages and if possible, could you share the code you used ?
Thanks in advance
PS : I think the problems lies in the STM32 emulation of the ELM327. Maybe not all AT commands are supported, but since the source code of the STM32 chips seems closed source, I don't know if we're going to end up getting those custom PIDs. But I don't think it's an hardware issue.
Thanks in advance
Thank you for the reply, Mr. Stanley. After going through the forum, I figured this is the problem.
Hello Alexandre,Alexandre wrote: Tue May 18, 2021 6:33 pm Hi Can_Bot,
I think we are trying to achieve more or less the same thing, but for other EVs (Renault ZOE and Peugeot e-208).
I would like to query some custom PIDs from 22 modes just like you but so far even the can_sniffing code isn't working (I only get the "uart: UART driver already installed" message when connected to those vehicles).
I'm wondering how did you end up sending those messages and if possible, could you share the code you used?
Thanks in advance
PS: I think the problem lies in the STM32 emulation of the ELM327. Maybe not all AT commands are supported, but since the source code of the STM32 chips seems closed source, I don't know if we're going to end up getting those custom PIDs. But I don't think it's a hardware issue.
Excuse me for the late reply. I haven't been on the forum for a long time as I could not find any solution to the problem. I've had the same problems as you've mentioned as well. The EVs use custom PIDs. So you cannot get any data from them using the Freematics hardware. We ended up ordering the expensive AutoPi after reading reviews on the Hyundai Kona Forum (https://github.com/JejuSoul/OBD-PIDs-fo ... /issues/22). Here is my code anyway if you want to try. Hope it helps.
#include <FreematicsPlus.h>
FreematicsESP32 sys;
COBD obd;
void testATcommands()
static const char cmds[][15] = {"ATZ\r", "ATI\r", "ATH1\r", "ATS1\r", "ATSP6\r", "ATDP\r", "ATS1\r", "ATSH7E4\r", "ATM1\r"};
char buf[128];
for (byte i = 0; i < sizeof(cmds) / sizeof(cmds[0]); i++) {
const char *cmd = cmds;
Serial.print("Sending ");
Serial.println(cmd);
if ((sys.link)->sendCommand(cmd, buf, sizeof(buf),1000)) {
char *p = strstr(buf, cmd);
if (p)
p += strlen(cmd);
else
p = buf;
while (*p == '\r') p++;
while (*p) {
Serial.write(*p);
if (*p == '\r' && *(p + 1) != '\r')
Serial.write('\n');
p++;
Serial.println();
} else {
Serial.println("Timeout");
delay(1000);
Serial.println();
void setup()
// USB serial
Serial.begin(115200);
// initialize co-processor link
while (!sys.begin());
// initialize OBD library
obd.begin(sys.link);
// send some commands for testing and show response for debugging purpose
testATcommands();
Serial.print(" BATTERY:");
Serial.print(obd.getVoltage());
Serial.print('V');
Serial.print(" CPU TEMP:");
Serial.print(readChipTemperature());
Serial.println();
// start CAN bus sniffing
obd.sniff();
Serial.println("CAN sniffer started");
