Connect Freematics ONE+ Model B with SIM7600E-H with german Telekom network
starfight
Post by starfight »
Hi folks,
I'm trying to use a german Telekom SIM card together with a Frematics ONE + Model B and the SIM 7600 E Shield.
To debug the connection flow I'm switched to the "sim7600test" firmware, enabled the verbose output with VERBOSE_XBEE = 1 and set the HTTP_TIMEOUT to 60000 (60 sec).
Since the Telekom requires a authentication for their APN I added the following lines to ClientSIM7600::setup(...) including the required parameters for user an pwd:
    if (user && *user && password && *password) {
      //sendCommand("AT+CSOCKAUTH=1,1,\"APN_PASSWORD\",\"APN_USERNAME\"\r");
      sprintf(m_buffer, "AT+CSOCKAUTH=1,1,\"%s\",\"%s\"\r", password, user);
      sendCommand(m_buffer);
    if (!success) break;
With this setup in place I get the following log over the serial interface:
[UART BEGIN]
[UART SEND]ATI
>UART RECV]OBD2USART V1.4
Bee Rx:35 Tx:2
Init cellular module...xBee power pin set to low
xBee power pin set to high
=== SENT@5659 ===
AT
=== SENT@6659 ===
AT
=== RECV@7259 ===
=== RECV@7259 ===
RDY
=== SENT@7659 ===
AT
=== RECV@7663 ===
AT
=== SENT@7663 ===
ATE0
=== RECV@7666 ===
ATE0
=== SENT@7667 ===
ATI
=== RECV@7681 ===
Manufacturer: SIMCOM INCORPORATED
Model: SIMCOM_SIM7600E-H
Revision: SIM7600M22_V1.1
IMEI: XXXXXXXXXXXXX
+GCAP: ==================
=== RECV@7684 ===
+CGSM
SIM7600E-H OK
IMEI:XXXXXXXXXXXXX
=== SENT@7692 ===
AT+CPIN?
=== RECV@7697 ===
+CME ERROR: SIM not inserted
=== RECV@8655 ===
+CPIN: READY
=== SENT@8705 ===
AT+CPIN?
=== RECV@8725 ===
+CPIN: READY
SIM Card OK
Registering on network...=== SENT@8725 ===
AT+CPSI?
=== RECV@8730 ===
+CPSI: NO SERVICE,Online
Repeated AT+CPSI? for some time, but finally:
=== SENT@9773 ===
AT+CPSI?
=== RECV@9886 ===
+CPSI: LTE,Online,262-01,0x5213,27001600,24,EUTRAN-BAND3,1300,5,5,-86,-885,-549,14
=== SENT@9887 ===
AT+CREG?
=== RECV@9892 ===
+CREG: 0,1
=== SENT@9897 ===
AT+CGREG?
=== RECV@9901 ===
+CGREG: 0,1
=== SENT@9906 ===
AT+CGSOCKCONT=1,"IP","internet.t-mobile"
=== RECV@9938 ===
=== SENT@9938 ===
AT+CSOCKAUTH=1,1,"??","t-mobile"
=== RECV@9950 ===
=== SENT@9950 ===
AT+CSOCKSETPN=1
=== RECV@9954 ===
=== SENT@9954 ===
AT+CIPMODE=0
=== RECV@9957 ===
=== SENT@9961 ===
AT+NETOPEN
=== RECV@9970 ===
=== SENT@9970 ===
AT+COPS?
=== RECV@9975 ===
+NETOPEN: 0
=== RECV@9983 ===
+COPS: 0,0,"Telekom.de",7
Operator:Telekom.de
Obtaining IP address...=== SENT@9989 ===
AT+IPADDR
=== RECV@9995 ===
+IPADDR: 10.208.129.110
10.208.129.110
=== SENT@10001 ===
AT+CSQ
=== RECV@10006 ===
+CSQ: 14,99
RSSI:-85dBm
Init HTTPS stack...=== SENT@10014 ===
AT+CHTTPSCLSE
=== RECV@10019 ===
ERROR
=== SENT@11022 ===
AT+CHTTPSSTOP
=== RECV@11028 ===
ERROR
=== SENT@12028 ===
AT+CHTTPSSTART
=== RECV@12041 ===
+CHTTPSSTART: 0
Connecting...=== SENT@12042 ===
AT+CHTTPSOPSE="hub.freematics.com",443,2
=== RECV@12051 ===
=== RECV@64167 ===
+CHTTPSOPSE: 15
+CHTTPSOPSE: 15
failed
=== SENT@72067 ===
AT+CHTTPSCLSE
=== RECV@72072 ===
ERROR
Actions I have taken so far:
- Test the SIM in a normal mobile phone -> Internet-access working
- Try the connection to a unencryped webserver on Port 80 -> Errorcode 10 instead of 15 received.
Does anyone have any suggestions or experience in to connect Freematics ONE+ or the SIM7600 with the german Telekom network?
What does the errorcode 15 (or 10) in the reponse: "+CHTTPSOPSE: 15" exactly mean?
Thx a lot
starfight
starfight
Re: Connect Freematics ONE+ Model B with SIM7600E-H with german Telekom network
Post by starfight »
Hi folks,
I have an update on this. The problem boils down to the fact that there is no DNS sever set for the PDP context. :? :?:
=== SENT@493265 ===
AT+CDNSSRV?
=== RECV@493268 ===
A ping to the Google-DNS works, so it's simply the missing DNS.
=== SENT@493268 ===
AT+CPING="8.8.8.8",1,1
=== RECV@493273 ===
+CPING: 1,8.8.8.8,64,53,255
+CPING: 3,1,1,0,53,53,53
Since the DNS won't be set automatically I want to set it mannually but I didn't found a way to do this.
Is there a way to set a fixed DNS server IP for the SIM 7600 Module?
Thx again
Starfight
tavius
Post by tavius »
Hello:
Did you find a solution for this? I'm trying with an O2 card in Spain and I have the same problem. No DNS server.
Thanks.
Octavio.
