Freematics One + not connecting via NET_SIM7600
daveywatt
Post by daveywatt »
I have purchased a new Telstra data SIM which has since been activated, however my Freematics One + won't establish a connection no matter what settings I try...
The sim is on a data only plan, and I have set the following:
#define NET_DEVICE NET_SIM7600
#define CELL_APN "telstra.iph"
#define SIM_CARD_PIN "XXXX"
The other settings are set to connect to hub.freematics.com via UDP and nothing else has changed in the code.
The hub never registers any connection data.
This is what appears in the console after an upload:
CPU:240MHz FLASH:4MB
IRAM:359KB
DEVICE ID:XXXXXX
TYPE:16
MEMS:ICM-20948
ACC BIAS:-0.00/-0.03/0.85
GNSS:OK
OBD:NO
STANDBY
ACC BIAS:-0.00/-0.04/1.03
CELL:SIM7600E
IMEI:XXXXXXXXXXXX
NO SERVICE,Online
SIM7600E OFF
GNSS OFF
Any help would be appreciated.
daveywatt
Re: Freematics One + not connecting via NET_SIM7600
Post by daveywatt »
This has been resolved.
Not sure what the issue was, but setting the config back to NET_WIFI and then reverting to NET_SIM7600 seems to have fixed it.
Could of been a strange SIM related issue...
Hickory1966
Post by Hickory1966 »
Hi. Such difficulties do arise periodically. I sometimes have to reboot the device. For example, I recently played at new no deposit casino mobile and the Internet disappeared altogether and I could not connect in any way. After the reboot, everything continued to work further. I think that this is just a malfunction of the equipment.
alexbelov11
Post by alexbelov11 »
One of the standout features of Winspirit Au is the immersive experience it provides. With high-quality graphics and sound effects, each game transports you to a different world. Check our website. Whether you're exploring ancient civilizations, diving into underwater adventures, or embarking on a quest for hidden treasures, the visual and auditory elements enhance the overall enjoyment and make you feel like you're part of the action.
storagenestle
Post by storagenestle »
Based on the information provided,dinosaur game it looks like your Freematics One+ device is not able to establish a connection using the SIM7600 module despite having a properly activated Telstra data SIM.
felixandrea
Post by felixandrea »
There are a few things you can try. First, make sure the APN "telstra.iph" is correct for your SIM; you can double check with your carrier. If the SIM doesn't require a PIN, you can try leaving the #define SIM_CARD_PIN "XXXX" line blank or deleting it. rice purity test meaning Also, check the signal strength of the SIM; you can try inserting the SIM into another device to see if it gets a signal.
Owenpaul
Post by Owenpaul »
Have you verified that the device is able to connect to other networks or tested it with a different SIM card to rule out hardware issues?
papa's scooperia
