Issues sending data via HTTP(s) using Freematics telelogger
daveywatt
Post by daveywatt »
I've been trying to get a simple HTTP post event sent from a FreematicsPlus device.
Sending via UDP is fine, but as soon as I set #define SERVER_PROTOCOL PROTOCOL_HTTPS I get the following errors and an infinite reboot.
I have not changed any other code, other than setting #define SERVER_HOST to my own server endpoint which is simply logging all request received to a file.
Once #define SERVER_PROTOCOL PROTOCOL_HTTPS as been set, the following is output in the console:
GNSS:OK
OBD:NO
WiFiGuru Meditation Error: Core  1 panic'ed (InstrFetchProhibited). Exception was unhandled.
Core 1 register dump:
PC      : 0x3f4025ea  PS      : 0x00060c30  A0      : 0x800d6aa9  A1      : 0x3ffb3db0
A2      : 0x3ffc1284  A3      : 0x00000014  A4      : 0x3ffc1284  A5      : 0x00000000
A6      : 0x3ffc1284  A7      : 0x00000009  A8      : 0x8015409d  A9      : 0x3ffb3d80
A10     : 0x3ffc1284  A11     : 0x3ffb3dbf  A12     : 0x00000001  A13     : 0x0000df80
A14     : 0x3ffc39a4  A15     : 0x3ffc39b8  SAR     : 0x0000000a  EXCCAUSE: 0x00000014
EXCVADDR: 0x3f4025e8  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0xffffffff
Backtrace: 0x3f4025ea:0x3ffb3db0 0x400d6aa6:0x3ffb3de0 0x400d165b:0x3ffb3e10 0x400d1a53:0x3ffb3f50 0x400d27d9:0x3ffb3f70 0x4008ce91:0x3ffb3fe0
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5828
entry 0x400806ac
E (132) spiram: SPI RAM not initialized
E (132) esp_himem: Cannot allocate memory for meta info. Not initializing!
Any help would be appreciated.
daveywatt
Re: Issues sending data via HTTP(s) using Freematics telelogger
Post by daveywatt »
I can confirm that any HTTP requests seem to fail..
Here is the output from a Freematics One + with the sim7600test.ino software:
SIM7600E OK
IMEI:XXXXXXXXXXX
SIM Card OK
Registering on network...OK
Operator:Telstra #StaySafe Telstra
Obtaining IP address...10.147.174.51
Init HTTPS stack...NO
Connecting...
+CHTTPSOPSE:0
failed
Connecting...
+CHTTPSOPSE:0
failed
Connecting...
+CHTTPSOPSE:0
failed
Connecting...
+CHTTPSOPSE:0
Any word from the developers on this? Could there be an issue with the SIM module on my hardware?
daveywatt
Post by daveywatt »
Here is the output from sim5360test.ino.
Same issue it seems.
Its worth noting that I have attempted this connect/send on both the hub.freematics.com:443 endpoint and my own server running HTTPS.
SIM7600E OK
IMEI:XXXXXXXXXXX
SIM Card OK
Obtaining IP address...10.140.140.178
Init HTTPS stack...OK
Connecting...OK
Sending request...failed
Connecting...OK
Connecting...OK
If you power from USB only instead of from OBD port, there is chance your computer's USB port can't supply enough current surge needed by cellular module.
daveywatt
Post by daveywatt »
Thanks. Is there a pin diagram available so I can supply 12v power while still testing via USB?
daveywatt
Post by daveywatt »
I have attempted this on a 5v/2A output and via a car OBD2 port.
If it helps, the cell connection works fine on stock telelogger.ino software with cell APN set to "telstra.iph" (Telstra SIM) and sim pin specified with PROTOCOL_UDP set.
This is to hub.freematics.com. The hub confirms my connection (showing 1m parked).
As soon as I set the config to PROTOCOL_HTTPS, it fails to connect.
daveywatt
Post by daveywatt »
Confirming this is still not working.
I suspect either an issue with the Freematics software or I have a SIM module hardware issue.
I have tried the following steps, both via a USB-C to MicroUSB serial connection that is supplies up to 2A power and via two seperate car OBD2 ports.
1. Cloned the latest Freematics code from Github
2. Loaded the firmware_v5/telelogger folder
3. Set CELL_APN to "telstra.iph" (Telstra SIM)
4. Set SERVER_PROTOCOL to PROTOCOL_HTTPS
5. Upload to device
In all tests, hub.freematics.com never recieves any data.
The end result is always "Error connecting to server" in the console.
After further debugging, I can confirm the issue is triggered/occurs at line 1049:FreematicsNetwork.cpp
(if (sendCommand(0, HTTP_CONN_TIMEOUT, "+CHTTPSOPSE: 0")) {)...
Also, this issue does not occur via WiFI or via SIM PROTOCOL_UDP.
Has anyone been able to get HTTPS working over SIM on their Freematics One +?
Thanks again.
daveywatt
Post by daveywatt »
This issue has been resolved thanks to Stanley. He's pushed up a fix to the repo.
Thanks again mate 👍
Macintosh666
Post by Macintosh666 »
I also had such problems, but I turned to my friend. It's just that I like to play more in https://mr.bet/at/game/view/demo/wild-water and I better understand this type of game. I think it's great that money can be made easily and quickly.
Rajeevmishri
Post by Rajeevmishri »
Thanks for sharing , This issue has been resolved thanks to Stanley. He's pushed up a fix to the repo.
