I have a ONE+ B. When I plug the device into my motorcycle's OBD the device does not power up, But when I plugin in to my car I no problem. I opened the ONE+ case and checked with a voltmeter pin 4 and 16 while plugged into the motorcycle. I have 12.7v.
I am validating if it is powered up only by the observing the blue light. I created a simple sketch that flashes the LED with no imports just a loop.
I am a bit mystified.
Thanks in advance,
Adrian
No power when powering from OBD
Re: No power when powering from OBD
I don't know much about motorcycles especially those with OBD port but I assume it should be same regarding to powering. Can you take a picture of the socket?
