Hey,
I consider buying a Freematics ONE+ Model B. Can You people make a recommendation of the flash memory size I should choose?
I'm planning not much development, since as far as I can see, everything I need is readily available:
- Log (maybe many) OBD live Parameters and GPS Data to SD card
- Upload them to a server (maybe freematics hub) via Wifi or LTE
What limits will I see with the 4-MB-variant?
Do all the modules offered by arduino builder fit together into 4 MB?
And finally: Can the memory later be extended somehow?
Thank You very much.
Flash Memory Size
Re: Flash Memory Size
Ok, meanwhile I managed to install the freematics builder and was able to build and see the flash memory consumption. WAY below 4 MB.
So, is what the builder shows all the utilization of flash memory I have to expect? (Of course using SD Card, not flash for logging)?
4MB is enough for most applications.
