Cooling down overheating
drlynass
Post by drlynass »
I get a cooling down message on the serial Monitor after about 15minutes. The ambient temperature is 20 degrees. Anyone know why I am overheating?
Re: Cooling down overheating
This is determined by the temperature reported by the MEMS chip which reflect the device internal temperature. Try reducing data rate. This happens when cellular signal is weak and the cellular module increases its power consumption. Alternatively, this can be improved by having an external cellular antenna.
Morgan75
Post by Morgan75 »
Thank you for all informations
