I saw that freematics HUB is open sourced and under GPL license. Unfortunately, I couldn't find the code repository of freematics hub.
Is it possible to access the source code for freematics hub software ?
Ahsan
						Freematics hub source code
Re: Freematics hub source code
Source code? I don't know but when i ran the server and the simulator js it ask for login account? Can anyone can help?
Do you mean the library? It is here https://github.com/stanleyhuangyc/Freematics
Thanks I see it under server folder.
I am testing my Freematics and installed the Freemtics hub but I have this show stopper..
Serial port COM3 opened at baudrate of 115200bps
Nearby WiFi APs:
1: test123 (-85dB)
MEMS...OK
ACC BIAS...0.00/-0.00/0.72
GPS...NO
WiFi...OK
IP...192.168.1.5
LOGIN(192.168.1.11:8081)...Server Error
Logout...
WiFi OFF
How should i login? is this supposed to happen? thanks.
Nearby WiFi APs:
1: test123 (-85dB)
MEMS...OK
GPS...NO
WiFi...OK
IP...192.168.1.5
Logout...
WiFi OFF
				ramsaymike
I have a similar problem - did you find a solution?
Thanks.
						Thanks.
