I need to connect my ONE+ to a IOT Platform (like thingsboard) unfurtunatly it seems there are no libraries for the SIM5360 available.  So seems I need to do it myself via HTTP Post and Json.
Is there any example code that could bring me on track?
						Connect to thingsboard.io
Re: Connect to thingsboard.io
The library for Freematics ONE+ has HTTP GET/POST implementation for SIM5360 which you can use as reference. You can also take a look at the traccar_client_sim5360 sketch with uses HTTP GET.
https://github.com/stanleyhuangyc/Freem ... im5360.ino
Thanks for the hint - got it working now! Still struggling with OBD.
Would you spend just 5 Minutes to connect via teamviewer or webex to help me out? I got an EV which doesn't respond to standard PIDs.
