Hi.
According to ESP32 docs, in order to use JTAG debug interfaces we need to access GPIO pins 12 to 15.
Is it technically possible to do so on the ONE+, hopefully via the XBee headers?
Thanks,
Andrea.
how to access JTAG pins on ONE+ ?
Re: how to access JTAG pins on ONE+ ?
If the pinout on this page, https://gojimmypi.blogspot.com/2017/03/ ... esp32.html, is correct, then when you open up your ONE+ you'll see that GPIO pin 12 is floating. It hasn't been soldered to a pad.
I have the same question. Any chance of using a USB debugger with GDB?
After some studying of the schematics, I'd say this can't be done, period: pin IO15 is used to control GPS power (EN GPS1) so it's game over.
See https://freematics.com/dl/FreematicsONE ... ematic.pdf
