Connecting Freematics One + to AWS IOT cluster
available
Post by available »
Is it possible to update the FreeRTOS to connect to Amazon IOT cluster ?
Or can we use the Amazon FreeRTOS installed on Freematics One + ?
Thanks,
Available
Re: Connecting Freematics One + to AWS IOT cluster
Of course you can. It's just ESP32. You can do anything that is possible on ESP32.
available
Post by available »
HI Stanley,
Thanks for confirming.
One more followup question : I am a software guy so limited knowledge on hardware. If i replace the existing freeRTOS with Amazon's FreeRTOS, do need a separate s/w, Device Driver for OBD II reader module as well or it will be taken care as peripheral attached to ESP ? In other words, do I need to install anything else after installing Amazon's freeRTOS.
Thanks in advance.
Thanks,
Available
