I want to sleep the freematics and have it turn on with the car, so it doesn't drain the power. Is there any way to do this? I looked at the sleep code in the telelogger and that seems to be a for loop that lasts untill the sleep time has been reached. I was looking more for a deep sleep.
I am also not sure if the car kills the power to the obd2 port when shut down. I read that some do and some don't.
Deep sleep
Re: Deep sleep
ESP32 can be switched to deep sleep mode but I haven't implemented it with APIs yet.
Re: Deep sleep
alright, do you have any plans to add it?
Having loads of fun playing around with it anyways. Bit of a shame i have to go down to the car to test stuff (The simulator is a bit expensive for a fun project:()
Re: Deep sleep
Hi triberraar,
here is an example for deep sleep. maybe it helps?
[code]
Simple Deep Sleep with Timer Wake Up
ESP32 offers a deep sleep mode for effective power
saving as power is an important factor for IoT
applications. In this mode CPUs, most of the RAM,
and all the digital peripherals which are clocked
from APB_CLK are powered off. The only parts of
the chip which can still be powered on are:
RTC controller, RTC peripherals ,and RTC memories
This code displays the most basic deep sleep with
a timer to wake it up and how to store data in
RTC memory to use it over reboots
This code is under Public Domain License.
Author:
Pranav Cherukupalli <cherukupallip@gmail.com>
#define uS_TO_S_FACTOR 1000000 /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP 5 /* Time ESP32 will go to sleep (in seconds) */
RTC_DATA_ATTR int bootCount = 0;
Method to print the reason by which ESP32
has been awaken from sleep
void print_wakeup_reason(){
esp_sleep_wakeup_cause_t wakeup_reason;
wakeup_reason = esp_sleep_get_wakeup_cause();
switch(wakeup_reason)
case 1 : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
case 2 : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
case 3 : Serial.println("Wakeup caused by timer"); break;
case 4 : Serial.println("Wakeup caused by touchpad"); break;
case 5 : Serial.println("Wakeup caused by ULP program"); break;
default : Serial.println("Wakeup was not caused by deep sleep"); break;
void setup(){
Serial.begin(115200);
delay(1000); //Take some time to open up the Serial Monitor
//Increment boot number and print it every reboot
++bootCount;
Serial.println("Boot number: " + String(bootCount));
//Print the wakeup reason for ESP32
print_wakeup_reason();
First we configure the wake up source
We set our ESP32 to wake up every 5 seconds
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) +
" Seconds");
Next we decide what all peripherals to shut down/keep on
By default, ESP32 will automatically power down the peripherals
not needed by the wakeup source, but if you want to be a poweruser
this is for you. Read in detail at the API docs
http://esp-idf.readthedocs.io/en/latest ... sleep.html
Left the line commented as an example of how to configure peripherals.
The line below turns off all RTC peripherals in deep sleep.
//esp_deep_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_OFF);
//Serial.println("Configured all RTC Peripherals to be powered down in sleep");
Now that we have setup a wake cause and if needed setup the
peripherals state in deep sleep, we can now start going to
deep sleep.
In the case that no wake up sources were provided but deep
sleep was started, it will sleep forever unless hardware
reset occurs.
Serial.println("Going to sleep now");
esp_deep_sleep_start();
Serial.println("This will never be printed");
void loop(){
//This is not going to be called
[/code]
[code]
Author:
void setup(){
++bootCount;
" Seconds");
deep sleep.
reset occurs.
void loop(){
[/code]
