I am curious if i am misunderstanding something. I noticed today that the real time temperature values are around 30 - 35 deg but when i look at the logged data for value 105 i am seeing reading in the 80's to low 90's. Is the temp field on the display not using pid 105 for it's reading? if not where is the temperature field getting it's data from? or can it be re-programmed to use the coolant pid 105?
hope that makes sense.
thank you
Real time temperature display vs logged temp value?
Re: Real time temperature display vs logged temp value?
What real time temperature are you looking at? 30s are about ambient temperature. 90s is correct for coolant temperatures.
Please post more information.
