Data Logger V4 - iOs connection via bluetooth? Logger as GPS-mouse?
cme
Post by cme »
Hello together,
is it possible to connect the Data Logger V4 to an iOS device via bluetooth to livestream the data received via the OBD port? I have seen that there is a ELM327 compatibility code which transfers the data into the ELM327 format.
But the tricky question is if the iPhone can connect to the bluetooth device. Because I know that iOS cna not connect to all bluetooth devices. Only "certified" devices or whatever can be connected. Therefore the question if this is possible.
And if it is possible... can I use the Data Logger V4 with an M8030 GPS module as a "GPS mouse" for my iPhone also? Forwarding the GPS position via bluetooth?
Many thanks in advance and best regards,
Chris
