Telelogger is not working for me I get this
#OBD....NO
#MEMS...OK
#GPS...OK
#GSM...OK
#GPRS...OK
#HTTP............
or
#OBD...NO
#MEMS...OK
#GPS...NO
#GSM...OK
#GPRS(APN:airtelwap.es)...OK
#HTTP.................
And keeps connecting for ever
if i use this command
AT+CREG?
I get
+CREG: 0,2 <---: still searching for an operator to register to
Which is valid for the telelogger code and then jumps to the HTTP part and loops forever
Im using vodafone chip in Spain, which works on mobile phone . PIN is not set for this SIM
Any ideas?
Problem with telelogger
Re: Problem with telelogger
I have this same problem, did you get this solved?
Signal issue. Check CSQ value.
Anyone have a working version of telelogger that's available for debug over USB?
