I want to display data in Serial Monitor
eraldino
Post by eraldino »
Hello good day! I finally got my hands on one of the OBD-II adaptor today and i tried out the sample sketch. All is good, the LED pin on pin 13 Lights up when my vehicles RPM goes beyond 3000 RPM but there seems to be something weird going on my Serial Monitor.
Here is my code:
I modified it a bit to display the data in the serial monitor.
* Sample sketch based on OBD-II library for Arduino
* Distributed under GPL v2.0
* Visit http://freematics.com for more information
* (C)2012-2014 Stanley Huang <stanleyhuangyc@gmail.com>
#include <OBD2UART.h>
COBD obd;
void setup()
Serial.begin(9600);
  pinMode(13, OUTPUT);
  obd.begin();
  while (!obd.init());
void loop()
  int value;
  if (obd.readPID(PID_RPM, value)) {
    digitalWrite(13, value > 3000 ? HIGH : LOW);
Serial.println(value);
http://imgur.com/a/2IlpN
I am using an Arduino UNO R3 and I'm trying to display the RPM data stored in "value" into the serial monitor attached here in this post is the screen shot of my Serial Monitor feed.
You can see that it's displaying weird data. This usually happens when there is a problem in the baudrate (in my experience) but i want to know first hand from the support team what I must do.
My real goal is to display all data in serial monitor and pass it on using Bluetooth,Serial,WIFI etc etc.
Re: I want to display data in Serial Monitor
Arduino UNO only has one hardware serial so you need to use software serial to output data to serial monitor. You can consider using Arduino MEGA which has multiple hardware serial.
