Depending on what PIDs are disabled/enabled, the AT command for the operation is generated incorrectly.
For example, the GUI generates the following command when some combination of enable/disable PIDs of the page "Throttle" is done:
ATSET 0140=91,3,bf,a3The correct AT command would be "ATSET 0140=91,03,bf,a3" (added a leading 0 on the second byte).
I managed to track the bug on the function togglePID(), contained in the file emulator.js.
Below is the corrected function:
function togglePID(pid, enabled)
   var i = parseInt(pid, 16) & 0xff;
   pidDisabled[i] = !enabled;
   var specialPid = i & 0xE0;
   var val = 0;
   var vals = "";
   var pidTmp = specialPid + 1;
   var valHex;
   for (m = 0; m < 4; m++) {
      val = 0;
      for (n = 1; n <= 8; n++) {
         val <<= 1;
         if (!pidDisabled[pidTmp++]) val |= 1;
      // vals += val.toString(16) + ",";  <-- toString(16) does not add leading zero in case val < 0x10
      // Corrected code. Always add a leading zero and do substr if necessary.
      valHex = ( "0" + val.toString(16) );
      vals += ( ( valHex.length > 2 ) ? valHex.substring(1) : valHex ) + ",";
   specialPid |= 0x100;
   var cmd = "ATSET 0" + specialPid.toString(16) + "=" + vals.substr(0, vals.length - 1);
   if (!sendCommand(cmd)) {
      alert("Unable to set PID " + specialPid.toString(16));
      return false;
   } else {
      alert("PID " + pid + " is " + (enabled ? "enabled" : "disabled"));
}I am not a JavaScript expert, so if there is a better way to do this, feel free to comment.
[]'s
Rhobison Alves Pereira
