Freematics OBD-II Emulator MK1
LMario
Post by LMario »
I'm using the Freematics OBD-II Emulator MK1.
I'm trying to get the speed with the below code, but I can't get any answer.
Probably I'm not making the request correctly.
Somebody can help me?
#include <mcp_can.h>
#include <SPI.h>
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 10;
MCP_CAN CAN(SPI_CS_PIN);                                                        // Set CS pin
#define ASK_PERIOD 3000
long timeLastSent=millis();
void setup() {
  Serial.begin(115200);
  while (CAN_OK != CAN.begin(CAN_500KBPS))
    Serial.println("CAN BUS Shield init fail");
    Serial.println(" Init CAN BUS Shield again");
    delay(1000);
  Serial.println("CAN BUS Shield init ok!");
unsigned char data[8] = {0x02, 0x01, 0x0D, 0X00, 0X00, 0X00, 0X00, 0X00};
void loop() {
  // Ask for speed to the Freematics OBD-II Emulator MK1
  if(millis()-timeLastSent>ASK_PERIOD)
    CAN.sendMsgBuf(0x10, 0, 8, data);
    Serial.println("Requesting speed...");
    timeLastSent = millis();
  // Check if data coming
  unsigned char len = 0;
  unsigned char buf[8];
  if(CAN_MSGAVAIL == CAN.checkReceive())
    CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
    unsigned char canId = CAN.getCanId();
    Serial.println("-----------------------------");
    Serial.println("get data from ID: ");
    Serial.println(canId);
    for(int i = 0; i<len; i++)    // print the data
      Serial.print(buf[i]);
      Serial.print("\t");
    Serial.println();
  delay(100);
