I2C doesn't work, 3 differents cars
CoCo24
Post by CoCo24 »
Sorry for my bad english.
I received the OBD2 Adapter Model B yesterday. I tried to connect the adapter to my car (Opel Vectra B from 1998) with "rpm_led_i2c" sketch. Sadly, the led doesn't turn on at 2000 RPM (I lowered to 2000).
I tried to explicitly specifiy the communication protocol in the header file but it's still doesn't work.
I have another scan tool (OP-COM) that works very well with my car and it says the car's communication protocol is KWP2000 (which is normally supported by the adapter).
I added some prints in the code and it's seems to be stuck on obd.init().
I tried the adapter on two other newer cars (Mini Cooper S from 2010 and Peugeot 206 from 2004) and it's still doesn't work...
I enabled "#define DEBUG Serial" but I don't get any debug print in the serial monitor. How can I get debug print ?
I wired the adapter to my Arduino UNO :
RED -> VCC (5V)
BLACK -> GND
GREEN -> SDA
WHITE -> SCL
What I have done wrong ?
Thank you,
CoCo24
Re: I2C doesn't work, 3 differents cars
Can you run the OBD example sketch obd_i2c_test and let me see what the output is?
bsxiong
Post by bsxiong »
Nothing i printed for me.
Please advise!
CoCo24
Post by CoCo24 »
Ok I try whenever I can
CoCo24
Post by CoCo24 »
Ok I tried obd_i2c_test and here is the output :
Sending ATZ
Timeout
Sending ATL1
Sending ATH0
Sending ATRV
12.0V
Sending 0100
UNABLE TO CONNECT
Sending 010C
UNABLE TO CONNECT
Sending 0902
UNABLE TO CONNECT
Init...
[35911]ATZ
[35969]ATE3
[36027]ATL1
[36084]0100
[38927]0100
[42720]104= 105= 10C= 10D= 10E= 10F= 111= 12F=
[42724]ACC=-13500/7792/-3512 GYRO=-288/19/65
[42726]104= 105= 10C= 10D= 10E= 10F= 111= 12F=
[42730]ACC=-13492/7740/-3304 GYRO=-292/-7/72
In the first try, ATZ returned "OBDUART v1.0" but ATRV returned "0.1V"
BrAjN
Post by BrAjN »
I got this problem with my Model B too.
I think my adapter is faulty cause i got the same result on three different cars, what i have to do?
Sending ATZ
BDUART v1.0
Sending ATL1
Sending ATH0
Sending ATRV
14.3V
Sending 0100
UNABLE TO CONNECT
Sending 010C
UNABLE TO CONNECT
Sending 0902
UNABLE TO CONNECT
Init...
[53074]ACC=-3720/3444/17268 GYRO=-107/184/-111
[53076]104= 105= 10C= 10D= 10E= 10F= 111= 12F=
[53083]ACC=-3784/3336/17164 GYRO=-91/184/-104
[53085]104= 105= 10C= 10D= 10E= 10F= 111= 12F=
[53091]ACC=-3640/3432/17180 GYRO=-97/187/-94
[53093]104= 105= 10C= 10D= 10E= 10F= 111= 12F=
[53099]ACC=-3580/3424/17288 GYRO=-59/167/-90
[53101]104= 105= 10C= 10D= 10E= 10F= 111= 12F=
[53107]ACC=-3704/3484/17252 GYRO=-60/119/-65
[53109]104= 105= 10C= 10D= 10E= 10F= 111= 12F=
If it's faulty, it won't respond to any commands.
If you try on 3 different cars which are all not KWP2000 or CAN bus, the adapter won't work on any of them.
CoCo24
Post by CoCo24 »
I tried on a car which is KWP2000 certified (work with another scantool and it says that the protocol is KWP2000)
I think KWP2000 protocol used by Opel is a bit different so I need to specify a custom init sequence...
I still look for a solution and I will return if I find a good way to run the adapter correctly !
