Hello Forum,
is it possible to put realtime Engine Parameters (like RPM, Oil-Temperature) trough the OBD-Emulator so that a connected OBD-Reader Shows this Parameters along with the emulated parameters?
Is there any Interface at the OBD-Emulator for that?
Sorry for my bad english.
regards
Frank
RPM-Signal
Re: RPM-Signal
You can programatically change the value of emulator's OBD-II PIDs by sending AT command via USB, BLE or serial UART (the 6-pin connector).
Re: RPM-Signal
Hello stanley,
thank you for the reply.
Do you mean I need to take my Engine-RPM-Signal and convert it to AT-commands?
In this case how many changes per second can be send through the Serial Interface.
Or I am on a wrong way ?
Sorry for these strange questions but I must emulate some PID's along with some realtime PID's so that a OBD-Tester shows These Parameters in once.
Regards
Frank
Regards
Frank
Re: RPM-Signal
The speed can't be very fast as for the 38400bps serial baudrate.
