avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/jason/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem143341
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e950f
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/var/folders/lp/db6ljhb56jnchnzc695wm3d80000gn/T/build7708092321181310918.tmp/datalogger.cpp.hex"
avrdude: writing flash (28948 bytes):
Writing | ################################################## | 100% 35.33s
avrdude: 28948 bytes of flash written
avrdude: verifying flash memory against /var/folders/lp/db6ljhb56jnchnzc695wm3d80000gn/T/build7708092321181310918.tmp/datalogger.cpp.hex:
avrdude: load data flash data from input file /var/folders/lp/db6ljhb56jnchnzc695wm3d80000gn/T/build7708092321181310918.tmp/datalogger.cpp.hex:
avrdude: input file /var/folders/lp/db6ljhb56jnchnzc695wm3d80000gn/T/build7708092321181310918.tmp/datalogger.cpp.hex contains 28948 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 21.55s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x042a
0x86 != 0xa8
avrdude: verification error; content mismatch
avrdude done. Thank you.Any ideas what is going wrong?
Thanks,
Jason
