Protocols except CAN do not work.
cavalier
Post by cavalier »
I have tested Freematics OBD-II Emulator MK2 with the Ultra-Gauge OBDII. But your product only support for CAN protocol. Another Protocol doesn't work. Please can check this issue?
Re: Protocols except CAN do not work.
KWP2000 is well supported.
cavalier
Post by cavalier »
You didn't check it. I think this product doesn't according to OBDII standard.
ngolden
Post by ngolden »
i am having a similar problem. i tried switching the protocol to anything other than CAN_11B_500K and i am having issues connecting.
I_Code_do_this
Post by I_Code_do_this »
Same problem here.
Works only with CAN 11/500 .
Has anybody found a solution?
After switching protocol, re-connect the device.
