IOS App
Keafer EDV
IOS App
Post by Keafer EDV »
I have some problems with your IOS-App. I try to connect my OBD-II Adapter with BLE to your IOS-App. Bit i will only see "connecting..."
In my Bluetooth devices I will see that my iPhone is connectet to the HMSoft device, but your App is still "connecting..."
What I have done:
- buy your ODB-II Adapter with BLW and the USBase-Stick
- set up the OBD Adapter with your elm327emu Scatch using USBase
- plug in the adapter to my car
- start the engine
- try to connect your app with your OBD Adpater
What can I do?
Re: IOS App
You should compile and download the datalogger_v2 sketch.
Keafer EDV
Re: IOS App
Theank you!
Now it works great with your own App.
My next Stepp is to build an own App. Is it acutally possible that you give me some informations how to read data from my OBD Adapter using an IOS APP?
So what I nedd is to get the complet OBD/ CAN-Interface Stream. Is that possible with your Adapter?
Thanks for your help!
Re: IOS App
You can't get "CAN stream". What you get is the value of OBD-II PIDs.
Keafer EDV
Re: IOS App
OK. So I can read the OBD PID's. Is there a way to get all information from the OBD-Device? Or will I get only the known PID's ?
Is it also possible to read the complete stream?
rosbel
Re: IOS App
Post by rosbel »
Hey Keafer, I got your private message, but I'm not able to reply. Definitely, send me some contact info where I can reach you, and thanks! I also got some parts figured out!
