Passes init(), but fails to read
Wehrdo
Post by Wehrdo »
Hi, I'm hoping to use this OBD-II adapter as an MPG gauge in my 2009 Scion tC, using the speed and MAF sensors.
Using the example sketch of turning a light on if RPM exceeds 3000 (I lowered to 1200), the light never turns on. Modifying that to also write to an OLED screen, so I can see that after a few seconds, it gets past the while(!obd.init()) portion, but calling obd.read(...) returns false. I'm sure my vehicle's protocol is supported, as all cars since 2008 are required to support ISO-15765-4.
Here's my code:
#include <Arduino.h>
#include <Wire.h>
#include <OBD.h>
#include <Adafruit_CharacterOLED.h>
COBD obd;
Adafruit_CharacterOLED lcd(OLED_V2, 6, 7, 8, 9, 10, 11, 12);
void setup() {
  lcd.begin(16, 2);
  lcd.print("starting");
  obd.begin();
  while (!obd.init());
void loop() {
  boolean succeed = true;
  int vss;
  int maf;
  if (!obd.read(PID_SPEED, vss)) {
    succeed = false;
  if (!obd.read(PID_MAF_FLOW, maf)) {
    succeed = false;
  if (succeed) {
    float mpg;
    mpg = 710.734 * vss / maf;
    lcd.setCursor(0, 0);
    lcd.print(mpg);
    lcd.setCursor(0, 1);
    char both [16];
    sprintf(both, "%d, %d", vss, maf);
    lcd.print(both);
  else {
    lcd.print("fail");
Any ideas? Thanks!
Re: Passes init(), but fails to read
Could you find another car to test?
Wehrdo
Post by Wehrdo »
Thanks for the quick response!
I also tested on a 2001 Chevrolet Cavalier, with the same results. Today I connected to the adapter with USB, so I could directly send commands and see the results. I can get something like the following:
Serial Console
atz
OBDUART v1.0
atrv
12.9V
0100 (I believe this is the command for seeing which PIDs are supported?)
SEARCHING...UNABLE TO CONNECT
So, as I suspected, the adapter runs, but cannot connect to the car properly.
Wehrdo
Post by Wehrdo »
Forgot to mention, I also can send the command "atsp0" with a response of "OK", meaning it successfully detected the protocol, right? Or does that just mean it successfully changed its mode to auto detect the protocol? I do this before sending command "0100", with the same error message.
The response of UNABLE TO CONNECT indicates that the car's protocol is not supported. ATSP0 just sets the protocol to auto detecting.
