I have an Freematics OBD-II Emulator MK1.
I've worked it with Sparkfun CAN-BUS shield. I has worked fine.
Now I want to configure it with the Freematics OBD-II Emulator program, but I get the errors:
1) When I press the button Connect I receive "Freematics OBD-II Emulator is not connected"
2) When I press the port button (p.e COM6) I receive "Error occurred during initialization"
Any idea?
Thanks.
p.s. I've loaded the driver "Silicon Labs CP210x USB to UART Bridge" without problems.
Issues with Freematics OBD-II Emulator MK1
Re: Issues with Freematics OBD-II Emulator MK1
I am sorry but the GUI software only works with MK2.
Thanks.
In the page http://freematics.com/store/index.php?r ... duct_id=53, I see the emulator MK1 can be configured via serial terminal. Do the configuration includes change the PIDs values?. If so, is there a manual to do it?
It is never said that the PID can be adjusted from serial terminal with MK1.
