Page 2 of 3
Re: Set MIL to Off ?
Posted: Thu May 07, 2015 5:24 pm
What specific DTC is still left on?
Posted: Fri May 08, 2015 1:06 am
by itsmagic
The DTC causing the MIL is P0105 and it cnanot be cleared from the UI or the serial port. The stored
freeze frame DTC's all say: "Fault Definition Not Available or Manufacturer Specific" on my OBD scanner.
They are also not clearable.
Posted: Sat May 09, 2015 10:12 pm
Please update the firmware of your emulator. Firmware is included in the GUI software package.
http://freematics.com/pages/software/fr ... lator-gui/
Posted: Mon May 11, 2015 9:56 am
by itsmagic
I installed the brand new firmware and GUI you mentioned above.
Unfortunately the new Version 1.0-20150509 firmware and GUI did NOT address the described problems.
After installing, MIL is still on, The freeze frame still has: DTCFRZF = P0105 and DTC_CNT is
still 6 with Six stored freezeframe DTC's. I tried clearing the DTC's and MIL... no joy.
*Please* fix this.
Posted: Mon May 11, 2015 6:22 pm
Did you upgrade the firmware? Latest firmware revision is 20150509.
Posted: Mon May 11, 2015 11:11 pm
by itsmagic
Yes. As stated in my post above: Version 1.0-20150509 firmware which is the latest.
The new firmware does not fix the MIL = ON or the freezeframe DTC's. If you try your's,
you will see it right away.
Posted: Tue May 12, 2015 9:09 am
I was informed by several emulator users that this issue is fixed by the firmware upgrade.
Posted: Wed May 13, 2015 3:54 am
by cuyusa
stanley can you explain how are we doing this?? with out individual help (team viewer) please or configurate the software when this issue affecting your wonderful product....
Posted: Wed May 13, 2015 4:03 am
by itsmagic
I have updated the firmware to the new level and repeated it a couple of times, all attempts have had the same results:
Hex file: Firmware_20150509.hex Installs, but MIL is still on with 6 Freezeframe DTC's
Hex file: Firmware_J1850_20150509.hex Installs, but the GUI will then not connect to emulator.
If others try this upgrade, please post and let us know your results.
Posted: Sun Aug 09, 2015 11:16 am
Please upgrade the latest firmware released in July 2015 and it will competely fix this issue.
