OBD-II Emulator MK2 without computer?
When working with the OBD-II Emulator MK2, does it have to remain connected to a computer to work? In other words, if I disconnect everything except the power supply, will it continue to send the information it was last set with (rpm, vin, etc)? If I then disconnect the power, will I need to re-program the emulator or will it start sending the same information it had before being unplugged?
Re: OBD-II Emulator MK2 without computer?
You can disconnect the emulator from computer and it will work as it is. The settings are not persistent so after powered off and on again, all values restore to default.
