i already did some CAN-to-MQTT-sniffing with arduino and an MCP2515, SIM800 and an GPS.
https://c2.staticflickr.com/4/3944/3308 ... bb62_z.jpg
I collect battery and charging data from my SMART-Electric-Drive and the Renault ZOE from my wife.
Both EV's.
Since SMART and RENAULT dont give me the open available data from the can bus in their web-apps, i collect them myself.
And i know from many other EV owners that they would like to have a simple solution too.
So i ordered the ONE+ because i really like the smaller form factor and the better developed hardware then mine in general.
But i'm a bit lost with the ONE+.
1. Which esp32 Board do i have to select in arduino for flashing?
At the moment i use "ESP32 Dev Module" setting, but maybe another setting would be better?
Is there a FreematicsONE+ Board-Setting i can copy into the hardware folder from my arduino so i can select it for uploading?
2. I already use a self made "Simulator" which works fine for my selfmade hardware.
But if i connect CAN-H and CAN-L to the ODB2 Ports the FreematicsONE+ dont recognize the can-bus.
So i canot test.
3. I use a AldiTalk SIM here in Germany.
My APN is "internet.eplus.de"
And i have a Username and a Login as well. In my sketches i have to give user/pass the SIM800 as well to work.
In the V5 Telelogger i have no user/pass, only a APN setting.
Where can i enter the user/pass?
If all works i will modify the CAN-ID's to get the ones i need for my EV's.
And in the best case i will send them with mqtt over gsm. But a http-POST/GET would work too.
Since im not sure if all works, i inserted an SD-Card for local logging, just to see sometning. But the Card is empty after a short drive.
Im a bit clueless where i can start to debug my problems.
Maybe soneone here can help or has already sometning made for a smart or a zoe.
Would like to exchange and test.
Thats all for the moment...
...eric
