reading traffic going to the emulator
cptreese
Post by cptreese »
what is the best way to setup seeing all the traffic going to the emulator? I want to connect an ELM327 to the emulator, send some commands and see how the traffic is being formatted. I also want to do this with my ESP32 connecting to the emulator via a CAN Shield
sparflaxseed
Re: reading traffic going to the emulator
Post by sparflaxseed »
You can use a CAN bus sniffer or monitoring tool, like Wireshark with a CAN interface, to capture and analyze the traffic between the ELM327 or ESP32 with the emulator.
Nanisa13
Post by Nanisa13 »
Use a library like ELMo to simplify communication between the ELM327 and your ESP32. This library allows you to send commands and receive responses synchronously bitlife
girlgolfing
Post by girlgolfing »
cptreese wrote: Mon Sep 30, 2024 10:35 am what is the best way to setup seeing all the traffic going togeometry dash the emulator? I want to connect an ELM327 to the emulator, send some commands and see how the traffic is being formatted. I also want to do this with my ESP32 connecting to the emulator via a CAN Shield
You can reverse-engineer the format or protocol being used between your devices and the emulator, particularly if you're sending standard commands through the ELM327 or ESP32.
