Hello everyone,
I am using SIM7070 freematics one+ and I am trying to connect to the AWS IOT core and I am using aws iot end point without ats and also a VeriSign Endpoints (legacy) and for CA certificate use VeriSign Class 3 Public Primary G5 root CA certificate because that's what's I read so far that it requires these conditions in order to connect but even after doing all these my connection to aws is still failing. When I put the certificates that I am using for my Freematics one+ in the Cygwin to confirm if my certificates are valid it does verify perfectly and I have also logged all the commands and their response which also comes out to be okay except the one with establishing connection to aws. So i don't know where I am making a mistake- is there someone who has managed to get the connection going for the SIM7070 Freematics one+ to aws MQTT. - please help me.
Thank you very much in advance
and I wish you all a nice day.
Connecting SIM7070 to aws MQTT
patrick893
Re: Connecting SIM7070 to aws MQTT
Connecting the Freematics One+ SIM7070 to AWS IoT Core requires attention to detail in certificate configuration and network setup. slope ball
