ISO 9141-2
Sergii
Re: ISO 9141-2
Post by Sergii »
Stanley, I understand, that code doesn't support ISO-9141-1, but does your hardware support ISO-9141-2?
Rathana21
Re: ISO 9141-2
Post by Rathana21 »
lbroph wrote: Tue Apr 07, 2015 9:46 am I just received my OBD-II adapter for arduino and I am having issues initializing.
Car: 2001 Saab 9-3
Protocol: ISO 9141-2
Arduino: RoboRED (UNO)
I cannot even get the example RPM sketch to work. It doesn't seem to connect to the car. Used oscilloscope to verify arduino is transmitting, downloaded and added libraries successfully.
I can compile and upload the example code to my UNO just fine (no errors). After uploading, Rx light blinks about once/3 seconds if i keep the UNO connected to the computer. Once I disconnect and use other power source (from OBD-II adapter) it doesn't blink anymore, but scope shows it is still transmitting.
****** Does anyone have this same problem or the solution to it??? *******
Below is the example code I tried.
* Distributed under GPL v2.0
* Visit http://freematics.com for more informationRegroupement de prêt immobilier
#include <Arduino.h>
#include <Wire.h>
#include <OBD.h>
COBD obd;
void setup()
pinMode(13, OUTPUT);
obd.begin();
while (!obd.init());
void loop()
int value;
digitalWrite(13, value > 3000 ? HIGH : LOW);
Me too I have a little problem on my OBD-II for Arduino
Help will be welcome
Devon
Re: ISO 9141-2
Post by Devon »
Old cars keep running but
Post by stanley » Sat Apr 18, 2020 12:45 am
J1850 is phasing out so we are not going to add support for it.
Tsk! Seek J1850 VPW support, any better vendors out there?
