Fail to find protocol, any guess?
wookhyun
Post by wookhyun »
I drive Kia Ray.
It's expected to SP6 (CAN 11bit/500Kbps) Freematics v4 fail to find protocol.
When I force set SP6, then it gives "CAN ERROR" for message
When I use other EML327-bluetooth dongle, it's working fine.
Freematics one page says only 11bit/250K is supported.
Can you check 11bit/500K is supported?
{code}
[4125]ATI
[4129]OBDUART v1.1
[4179]ATZ
[4184]OBDUART v1.1
[4234]ATE0
[4238]OK
[4288]ATL1
[4292]OK
[4342]ATAL
[4346]?
[4397]ATS0
[4401]OK
[4451]ATRV
[4454]14.1V
[4505]ATAT1
[4508]?
[4558]ATSP0
[4562]OK
[4613]ATDP
[4617]AUTO, ERROR
[4668]ATSH7E4
[4672]OK
[4722]2101
[7465]SEARCHING...
UNABLE TO CONNECT
{code}
protomor
Re: Fail to find protocol, any guess?
Post by protomor »
I can't see your code but how are you initializing the OBD class? Default is "PROTO_AUTO" but I've had to manually force it a few times. I think you're looking for PROTO_CAN_11B_500K .
You can look in the OBD.H for more informatoin but here's the enum definition.
typedef enum {
PROTO_AUTO = 0,
PROTO_ISO_9141_2 = 3,
PROTO_KWP2000_5KBPS = 4,
PROTO_KWP2000_FAST = 5,
PROTO_CAN_11B_500K = 6,
PROTO_CAN_29B_500K = 7,
PROTO_CAN_29B_250K = 8,
PROTO_CAN_11B_250K = 9,
} OBD_PROTOCOLS;
wookhyun
Post by wookhyun »
Thank you for reply.
I also tried "PROTO_CAN_11B_500K = 6".
In this case, ATSP6 gives OK.
But actual data "2101" gives "CAN ERROR".
The code is modified version of "FreematicsONE.cpp".
I added commands to "bool COBDSPI::init(OBD_PROTOCOLS protocol)" for test purpose, so that I can see the response from OBD.
protomor
Post by protomor »
I don't have the list in front of me. What's the 2101 command?
I don't have the one so I don't know much about how it works. I'm at the limit of how I can help you.
