How can I use other pins than the RX-TX (pins 0 and 1) default pins?
Thank you,
Serial Communication
Re: Serial Communication
But in the Arduino OBD library, there's no constructor with pins arguments!
obd.begin();
obd.init();
How can I read from different pins than those for Serial and Serial1? (and how to write after?)
obd.begin();
obd.init();
Arduino side programming is not enough!
The Arduino OBD library only use Serial or Serial1! Maybe you can create a constructor with arguments for letting us choosing pins for communication please!
i need the same.. anyone know if its possible or how can we change the library to use softwareserial?
