I am trying to use OBDII Emulator without the GUI. My problem is related to ATSET [PID]=[Value] command. As according to OBDII documentation Engine Coolant Temperature PID ranges from -40 to 215 ºC, I set the lowest value -40 using "ATSET 0105=-40", however it returns ERROR repeatedly. Can't PIDs be set to negative values at all or is there anything I am doing wrong about this command?
Thanks,
Thales
ATSET [PID]=[Value] ERROR for negative values
Thales.Portela
Re: ATSET [PID]=[Value] ERROR for negative values
PID data is a unsigned one byte or two bytes data. You need to map the actual value to the PID value first before pushing it to the emulator.
