Issues with kit. (Subaru Impreza 07 1.5)
SeanWHannon2
Post by SeanWHannon2 »
I bought the #3 Telematics kit. The first issue is that the device keeps resetting when plugged into the OBD-II port. It will start up fine, display the car data using the Megalogger sketch from github https://github.com/stanleyhuangyc/ArduinoOBD/tree/master/megalogger. I amen't sure why this happens.
But since trying to upload the sketch again I got the issue from the images attached. (Sorry couldn't get image small enough to upload so had to use dropbox links)
https://dl.dropboxusercontent.com/u/216 ... .23.05.jpg
https://dl.dropboxusercontent.com/u/216 ... .23.38.jpg
https://dl.dropboxusercontent.com/u/216 ... .24.29.jpg
Anyone have idea how to fix these issues?
Also as side note a proper tutorial on how to program the device would be great to have if anyone has a link?
SeanWHannon2
Re: Issues with kit. (Subaru Impreza 07 1.5)
It seems that the lcd.print function isn't working correctly and only printing out the 1st character of the word.
I've tried re-downloading the libraries and didn't work. Anyone have an idea why this might happen?
I'm using the Arduino 1.6.7 ide if that matters.
SeanWHannon2
With the latest and greatest version from github repo I get these warnings and amen't sure if these are the issue or not to the problem where only first character appears. I don't know if this is a hardware fault or software issue.
In file included from C:\Users\Sean\Downloads\ArduinoOBD-master\megalogger\megalogger.ino:13:0:
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:55:43: warning: '__progmem__' attribute ignored [-Wattributes]
     virtual void draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height) {}
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:56:43: warning: '__progmem__' attribute ignored [-Wattributes]
     virtual void draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height, byte scaleX, byte scaleY = 0) {}
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:57:47: warning: '__progmem__' attribute ignored [-Wattributes]
     virtual void draw4bpp(const PROGMEM byte* buffer, uint16_t width, uint16_t height) {}
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:113:35: warning: '__progmem__' attribute ignored [-Wattributes]
     void draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height);
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:114:35: warning: '__progmem__' attribute ignored [-Wattributes]
     void draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height, byte scaleX, byte scaleY = 0);
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:115:39: warning: '__progmem__' attribute ignored [-Wattributes]
     void draw4bpp(const PROGMEM byte* buffer, uint16_t width, uint16_t height);
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:186:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:187:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:242:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:243:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:244:39: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:297:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:298:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD/MultiLCD.h:299:39: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\OBD\OBD.cpp: In member function 'virtual void COBDI2C::write(const char*)':
C:\Users\Sean\Documents\Arduino\libraries\OBD\OBD.cpp:482:35: warning: narrowing conversion of 'millis()' from 'long unsigned int' to 'uint16_t {aka unsigned int}' inside { } [-Wnarrowing]
  COMMAND_BLOCK cmdblock = {millis(), CMD_SEND_AT_COMMAND};
C:\Users\Sean\Documents\Arduino\libraries\OBD\OBD.cpp: In member function 'bool COBDI2C::sendCommandBlock(byte, uint8_t, byte*, byte)':
C:\Users\Sean\Documents\Arduino\libraries\OBD\OBD.cpp:491:35: warning: narrowing conversion of 'millis()' from 'long unsigned int' to 'uint16_t {aka unsigned int}' inside { } [-Wnarrowing]
  COMMAND_BLOCK cmdblock = {millis(), cmd, data};
In file included from C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\ILI9325D.cpp:9:0:
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:55:43: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:56:43: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:57:47: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:113:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:114:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:115:39: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:186:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:187:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:242:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:243:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:244:39: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:297:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:298:35: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.h:299:39: warning: '__progmem__' attribute ignored [-Wattributes]
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\ILI9325D.cpp:398:45: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_ILI9325D::draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height)
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\ILI9325D.cpp:414:45: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_ILI9325D::draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height, byte scaleX, byte scaleY)
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\ILI9325D.cpp:435:49: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_ILI9325D::draw4bpp(const PROGMEM byte* buffer, uint16_t width, uint16_t height)
In file included from C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\ILI9341.cpp:10:0:
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\ILI9341.cpp:480:44: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_ILI9341::draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height)
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\ILI9341.cpp:497:44: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_ILI9341::draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height, byte scaleX, byte ScaleY)
In file included from C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\MultiLCD.cpp:9:0:
In file included from C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\R61581.cpp:9:0:
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\R61581.cpp:341:43: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_R61581::draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height)
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\R61581.cpp:366:43: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_R61581::draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height, byte scaleX, byte scaleY)
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\R61581.cpp:398:47: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_R61581::draw4bpp(const PROGMEM byte* buffer, uint16_t width, uint16_t height)
In file included from C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\SSD1289.cpp:9:0:
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\SSD1289.cpp:269:44: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_SSD1289::draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height)
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\SSD1289.cpp:294:44: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_SSD1289::draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height, byte scaleX, byte scaleY)
C:\Users\Sean\Documents\Arduino\libraries\MultiLCD\SSD1289.cpp:326:48: warning: '__progmem__' attribute ignored [-Wattributes]
 void LCD_SSD1289::draw4bpp(const PROGMEM byte* buffer, uint16_t width, uint16_t height)
Sketch uses 58,232 bytes (22%) of program storage space. Maximum is 253,952 bytes.
Global variables use 2,605 bytes (31%) of dynamic memory, leaving 5,587 bytes for local variables. Maximum is 8,192 bytes.
I removed the obd-ii cable just to eliminate anything so.
Current code running on board
